Anybody know how to test a speed and tdc sensor?????????
rich201283
Unread post by rich201283 »
Peugeot 406 1.9dt 1998
I have tested the tdc sensor by unplugging the injector sensor and the tacho works.
How can i test the speed sensor????????????????????????
Also does anyone know what sensors the car uses to feed the ecu with information as it appears to not be adjusting the timeing????????????
Regards Lee
x 1060
Unread post by wheeler »
the best way to test an inductive sensor is to use an ociliscope if you have access to one
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
TD doesnt have electrically adjusted timing? or does it.. newer ones could do hmmm
pull the sensor out and insert a bit in and put on a drill...
presumably the speedo itself works?
john
jgra1
(Donor 2021)
x 36
sorry ignore me
i am being quite silly today ;)
J
