Xantia: Rear break disc removal
Rostami
Unread post by Rostami »
Hi to all,
Simple question: the head of the screw that secures the rear break discs looks quite strange to me? The screw also acts like a guide for the wheel.
What kind of instrument should I unscrew it with?
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
mpr1956
Unread post by mpr1956 »
Hi there.. there may be a proper tool for this pin, but I used mole grips and they worked a treat !
I won't do that again
KennyW
x 163
Unread post by KennyW »
HI Rostami,
I've just my done my brakes and it was a T55 or T60 with a ratchet for the front brakes but it was a normal hex bolts on the rear.
Maybe it the torex headed bolt.
Cheers
KennyW
C3 1.4 petrol (SWMBO)
KennyW
x 163
Hi Rostami,
Are you talking about the small crossed head screws holding the disc onto the hub or the screws holding the disc onto the caliper :?:
Cheers
KennyW
x 1480
No he's talking about the special bolt that holds the disc on the rear - I guess it suposed to have a hex on it, then a round pin that sticks out to located the wheel. usually the hex has rusted to a nothing. Mole grips, or file some flats on it, or weld a nut on it and use a new one on refitting.
slim123
Unread post by slim123 »
5.5mm socket, unless someone has used molegrips before, then it will have to be molegrips again!!!
Regards
Slim
Rostami
Hi to all!
Thanks for your prompt answers.
In fact it is a 5.5mm socket!
Rostami.
slim123
=D>
Regards
Slim
NiSk
Unread post by NiSk »
Only Citroën would . . . .! (mind you I got really dischuffed when I finally worked out that Volkswagen use a 7mm allen socket bolt to hold the brake caliper on the Passat)
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
