Hi
Does anyone know how to disable or turn of and disconnect the key code imobiliser in a 98 Citroen Dispatch. Im sure it would be the same method for other citroen and peugoet models.
Many Thanks
Karl
Citroen number code imobilisor
Hi
I have the code of the imobilisor, the one that you must type in each time the car is started. However, I have recently fitted a new engine with a different fuel pump. The original fuel pump had four (or maybe 5) wires going into it. The new pump only has one which I guess requires a 12 v supply to allow fuel to flow.
Regards
Karl
Regards
Karl
Karl -
You dont seem to understand that the wires you have (to the original now removed unit) carry the code - not a switched +12V from ignition switch.
You can NOT use these wires anymore now - as there is no module to interpret the code
As others have tried to tell you :
You need to find a DIFFERENT wire from the ignition switch - which will carry the +12V from the ignition switch - WHEN the ignition key is turned ON.
Very likely you will have to install a new wire especially for this purpose.
This you connect to the fuel solonoid. Its dead easy.
Anders (DK) - '90 BX16Image
