Blower started working intermittently, then it just got less and less likely that it would run at all.
Car is a '96 2.0l 16v petrol, with air-con. After ripping the steering column to bits to check the ignition switch, I then went to pull the blower itself.
On the blower itself there's 1 plug, a 4-pin, taking the feed and earth to the resistor pack (actually mounted on the motor itself), and I assume the speed control wiring. Then there's a red and black wire from the resistor pack to the motor itself. Looks like the feed from the resistor pack to the motor had overheated (all black and crusty, crimp cover melted - all classic signs!) at the resistor pack end.
Soooooo.... would I be right in thinking a trip to the scrappy is in order for a replacement motor, as the resistor pack is in-built to the motor?
Any and all suggestions appreciated!
