HDI turbo whistle
steelcityuk
HDI turbo whistle
Unread post by steelcityuk »
How much noise do HDi's make when coming onto boost? Mine seems to be quite noisy and I think I should be checking the hoses. Does the 110 make more noise than the 90? Also how much more powerful do you think a HDi 110 will/should feel compared to a 1.9 TD?
Thanks.
Steve.
not applicable
x 1240
Unread post by Peter.N. »
Turbo's seem to be very individual in their noise output, if it has suddenly started making more noise than usual, check the inlet hose and exhaust, otherwise I wouldn't worry.
f00lzz
Unread post by f00lzz »
If it has suddenly started to sound 'quite good' i.e. with a nice loud whistle when you come on boost.... I would get the exhaust checked out for leaks perhaps around the manifold to downpipe joint
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
deian
Unread post by deian »
yes, i agree, check for a leaks in the exhaust, i had a crack just before my cat before and the turbo's noise was louder, it was getting to the point of annoying, more likely the closer to the engine the hole/crack in the exhaust is the louder the turbo gets, it is louder because of the lack of back pressure on it, so it spins on any pressure.
