LHM in Drivers Footwell!!!!
I've got LHM in Drivers Footwell!!!!
It looks like its from the brake valve, in fact I am sure it is.
Is there a quick win for this or not?
Has anyone removed a brake valve?
The car is a 1993 1.9TD sx Xantia with abs, no aircon.
Tips please on a postcard
Paul
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
I had this on my old xantia 1.8i sx. Its not too bad a job, usual fiddly replacing of high pressure pipes and seals but not too bad.
"Rust Never Sleeps" said Neil Young. Did he own old citroens?
1998 Xantia TD exclusive auto estate +3 x BX's +77' ami 8 break + 73' dyane 6 + '83 2CV6 + 94' XM 2.1 sx auto + 89' XM2.0i
+ '85' GSA + '97 XM 2.0 16v + '81 Visa super E
well i've discovered that about 5 years too late
good tip to remember though.
i have only done one quite a while ago but im sure i removed the two intercooler pipes which go down the rear of the engine,then frm inside the car undo the two nuts that hold the dozer valve to the bulkhead,then ease the dozer valve into the engine bay enough to gently bring the pedle end aronud to face you,be carefull not to damage any of the pipes,then prize out the aluminium ring which holds the rubber dome in place,and remove the dome,refit and bobs your uncle whatsits you aunt
regards malcolm
regards malcolm
Hi, Well, I did it.....
Removed the underdash on drivers side, Found the two nuts, found out my sockets weren't long enough, got an old box spanner, removed nuts, removed turbo intake pipes, carefully pulled the dosier valve out and replaced the rubber seal/dome and ring. Sore hands, but job took about 2 hrs, took longer to remove the sodden carpet and power wash the carpet to remove the LHM.
Thanks a lot Citronut for your help
Paul
Paul
how many parts did you end up buying as i would not have thought you should be charged that much just for the rubber protector and securing ring,and yes i think you are ment to get some discount from citroen when being a CCC member,maybe you should have said your a member of the KKK whooops!!!!!!!!
regards malcolm
regards malcolm
