xantia HDi cutting out at low revs
Tinnie56
Unread post by Tinnie56 »
I've got an X reg Xantia HDI 110bhp, that has started to cut out when coming to slow stop, it only happens when coming to a slow halt, engine started after about 5 minutes
An auto electrician diagnosed the fault code 230, this could be one the following 3 - (1) a wiring short, (2) fuel shut off valve, (3) a ECU fault.
To date, I have the high pressure fuel pump replaced as the fuel shut off valve is not available seperately,and the fuel filter housing.
Completed about 150 miles over the last few days, and yesterday same fault recurred 3 x times,, but started immediately on the key.
Anyone got ideas what is the cause?
Tinnie56
