The rain sensor appears to have stopped working on my 306. When I put switch the wiper stalk to the auto position, the wipers do work, but with the same intermitent delay, irrespective of squirting water directly on the sensor.
When looking at the sensor through the windscreen, there is a orange light on the left hand side which I guess means the sensor has power....any ideas on what the problem could be?
2001 306 rain sensor problem
check where sensor fits the screen,if it defaults every 4.5 seconds this could be the problem,if screen is cracked across sensor the light prism bounce off the crack default is then 4.5 sec ,also check on sensor should be 2 gel pads in sensor,if had screen change these can stick on the old screen
EP6T petrol turbo nice engine in the 207 GT and the new mini....
