The engine is a 110Hdi diesel by the way. The day after collecting the car, I was driving to work when it showed 'Antipollution Fault', and went into limp home mode. I duly limped home, disconnected the battery for 10 minutes, and checked all the pipes to and from the turbo, etc, to ensure there were no air leaks, everything looked fine, so I reconnected the battery, started the engine, and drove happily away. However, I've noticed that when I first drive off in the morning the car feels as if it's still in limp home mode, then after a minute or two, if I take it up to a couple of thousand revs it shoots off like a scaled cat and normal performance is resumed.
I've had no warning mesages showing since clearing them, but does anyone know where I should be looking to fix this. Though I guess I could live with it, no danger of abusing a cold engine at present
