Hello, I've got a 1995 Xantia 1.9 TD, earlier today I put the car on the highest suspension setting to top up the LHM fluid, when I put it back to the middle setting the front of the car dropped to the normal height but the back didn't, It'll go to the lowest setting front and back and the highest but the back of the car won't go to the normal driving position, does anyone have any ideas what could be causing this?
Thanks,
Fangy.
back of xantia doesn't rise
Hi Fangy.
You are gonna need a replacement rear height corrector, if you replace the plastic link you will certainly run the risk of snapping off the metal link to the anti roll bar.
Lubrication can sometimes (rarely) work, but all the WD40 in the world will not creep in behind the plastic bushes, this is where the corrosion is.
Have a look at this previous post and you will see what you are fighting with.
http://www.frenchcarforum.co.uk/forum/v ... highlight=
Regards
Slim
Regards
Slim
Regular lubrication is fine and a great idea, before the problem sets in and again after the height corrector is replaced, but it aint gonna fix a knackered one.
Any decent garage will having known the fault, spray the linkages at every service to help keep out the water and dirt.
The best in my opinion is spray on grease, this will leave a sticky residue and help to seal against water getting in.
The biggest problem is, as with lots of parts on the modern cars, is the fact that everything is assembled dry!! not a drop of grease or oil anywhere.
Remember the old Morris?? even the handbrake cables had grease nipples.
Regards
Slim
Regards
Slim
As suggested, it may be better to put your hand in the pocket and pay someone to change it.
The height corrector is fairly easy to change, but unless you have all four wheels on the ground and the car in the air, ie on a ramp, it is a bugger to set the heights up.
If you realy want to change it yourself, you will need an 8mm spanner for the pipes and a torx bit No45 (I think) for the 3 x mounting bolts, looking at the job it is fairly self explanitory.
Regards
Slim
Regards
Slim
Prefereably one that 'understands Xantia's' Your profile doesn't give a clue to your location so it's difficult to recommend a good garage.fangy wrote:I think I'll book it in to my local garage for this, I've got no way of setting the heights up once I change the height corrector.
Thanks for the help,
Fangy.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
The height corrector will be OK - its the linkage - right up to the corrector thats at fault - either siezed or bent.
Certainly BX linkages respond well to lubrication.
Be very carefulk working underneath hydraulic citroens - especially on the height correctors and linkages. IF the car descends unexpectedly it will KILL you - and yes it does happen.
jeremy
