V6 W reg water leak
firesam999
V6 W reg water leak
Unread post by firesam999 »
Hi i seem to have a leak in the engine bay but only when i put the fan on it drips somewhere around the right hand side about halfway i cant see where it leaks from my first xantia dont know engine at all
f00lzz
Unread post by f00lzz »
When you put the fan on?? Are we talking Heater Blower Fan then?
Have a look around the expansion bottle... they are known to leak at the joint which runs around the middle of the bottle. Cant see what either the Heater Blower Fan or the Radiator Cooling Fans would do to cause a water drip tho'.
Your first Xantia and you bought a V6..... How brave :twisted:
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
firesam999
leak
Yes sorry i put the heater fan on in the car and the water drips out in the engine bay
Dave Burns
Unread post by Dave Burns »
Is this water in actual fact the condensate discharge from the aircon, this will be on the right when viewed from the front.
Dave
f00lzz
To be honest I can't think of a possible connection.... the Heater Blower Fan is located underneath the passenger glovebox and is accesible from the passenger footwell.... It isn't connected to the water system, it just blows air across the Heater Matrix.. Just a thought, is the drainage channel clear of debris (located nearside just below the front windscreen). If this gets blocked perhaps water gets thrown by the Heater Blower Fan... A long shot I know, but I can't think of anything else at the moment.
By the way... whereabouts in the UK are you located??
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Stempy
Unread post by Stempy »
I agree with Dave, move the airflow slider away from the windscreen position and the aircon will turn off unless you manually switch it on with the aircon button. When the slider is in the screen position the aircon is automatically cut in to clear the screen quicker.
Lexia ponce
firesam999
leak
Im in Leeds i cant understand it i thought same no water passes the heater fan/ condensation i thought but theres a continual fast drip when fan is on/ happens with air con on or off/ turn fan off it stops / does the heater matrix do anything different when i put the fan on ive only had the car 4 months but its had a new matrix, seals and antifreeze less than a year ago new radiator 6 months ago and an expansion bottle 18months ago
f00lzz
Stempy wrote:When the slider is in the screen position the aircon is automatically cut in to clear the screen quicker.
Are you sure?? Mine doesn't!!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
NiSk
Unread post by NiSk »
If you can collect some of the water and discover that it is clear water (not coloured coolant) than this is just the normal condensate from the A/C running off. It does the same on all cars fitted with A/C.
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
Clogzz
x 40
Unread post by Clogzz »
f00lzz wrote:Mine doesn't!!
Neither does mine, as it’s a Mk I.
Thought both yours were Mk II’s from your signature.
The Mk II is supposed to turn on the air conditioner when you set the slider to demist the windscreen.
f00lzz
Nope! Tried it earlier today just to be sure.... the compressor only kicks in once I activate the A/C button!!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
