So just had the oil and filter done at kwikfit (there useful for something) and they pointed that there is a leak from the front of the CAT on the exhaust.
Now they quoted a silly price of £264 which I now is way over as I can get it for far less from Euro parts and do it myself.
My question is I believe that I once read that a diesel doesn’t need a cat or at least not for the MOT so can a basic by-pass pipe be bought or is it best to get the cat?
sorr forgot to say its a 1999 110bhp 2.0HDI xantia
HDI xantia cat
CitroenNuts
HDI xantia cat
Homer Simpson: Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel
howiedean
Re: HDI xantia cat
No you'll be OK to by-pass it there are some posts about this if you do a search.CitroenNuts wrote:So just had the oil and filter done at kwikfit (there useful for something) and they pointed that there is a leak from the front of the CAT on the exhaust.
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
deian
I had a hole/leak where you have yours, IF the exhuasts are the same (i have a 2.1td) and u have (hdi) i was quoted £164 for a cat (one piece down pipe including cat going into the middle box). I still said repair the hole, and they did for £30, so ask the exhaust people nicely to repair it. Shouldn't be a problem should it.
Good luck.
Good luck.
_kid_
CitroenNuts
There is a hole about an 40mm long and about 4mm wide just looks like a weld has rusted then fallen off.
i'll see if I can get it welded as last time I tried to weld one i blew a bigger hole in it
Thanks for the help
Thanks for the help
ssray
