oh dear my xantia has sprung a small but expensive lhm leak (ahhh reminds me of my old bx).....its getting through a litre of lhm every week
anyway its leaking from underneath the fluid container....appears to be from a small box thingy with lots of pipes running into it (havent taken my socket set to it yet to try to track the leak down properly)
so whats the name of the small box thingy underneath the fluid container (oh and it hasnt got ABS so its nothing to do with that box) does the little box thingy tend to leak (or is it likely to be just a loose pipe connection)
oh in case you hadn't guessed i really have very little idea how the 'magic suspension' system works!
any help gratefully received
Cheers
xantia lhm leak
weety
xantia lhm leak
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
slim123
weety
yep that looks just like it (except mine is covered in a ecological mixture of lhm and dirt)slim123 wrote:That will be the Anti Sink Valve, the front one is located under the reservoir and is a common leaky bit, best you change it soon!!
Snagged this from the Pleiades web site.
Should look like this and will have fluid coming from the blanking plug on the end.
Regards
Slim
cheers.....now wheres my gsf catalogue............
slim123
mezuk04
JohnD
- x 72
If your anti-sink is showing signs of leaking, change it quickly. Mine suddenly dumped the entire reservoir of LHM leaving me stranded without suspension, brakes or power assist. To be on the safe side, I changed the rear one as well. GSF have them for less than £60.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
weety
cheers for the help, unfortunately i am down south so cant get to Pleiades, i will probably do it myself this weekend (if i can get the part in time)
slim123
HA HA !!!
Slim works for no-one, Slim is semi retired and only ventures out under certain conditions.
When he wants to
If he feels like it
When the money is right
When the above criteria is filled, Slim will work !!!
I allways pick up the bits from Pleiades as they are not to far from me, the prices are ok, the quality is good, and it all has a 2 x year warranty.
Also Pleiades supply DS hydraulic parts, I have spent a lot of my past working on the DS (cos not a lot of people want to)
Regards
Slim
When he wants to
If he feels like it
Regards
Slim
JohnD
- x 72
[quote="weety"]i will probably do it myself this weekend quote]
Quite straightforward to do. Rear is easier. Front access via removing battery, but also from underneath to undo fixing bolt. Pipe seals will be left behind in the old valve, which you'll need unless you buy new ones.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
weety
top hint i will make sure i get new pipe seals as well.....JohnD wrote:weety wrote:i will probably do it myself this weekend quote]
cheers for that.....
