I get a grinding noise after heavy braking, when the brakes are hot. My pads and discs are worn but within spec. I am sure the noise is from the front brakes.
Could it be heat affecting the wheel bearings?
Any ideas?
Simon
Car is a ZX TD, 1997, with Lucas brakes. 109k miles.
ZX brake noise- only under heavy braking
Stewart(oily)
- x 35
Village
I recently (last week) changed the front discs and pads on my ZX, and I found that some of the grinding noise appeared to be from the wear sensor wire getting trapped between the pad and disc (and the lack of any meat on the pads)
it might be worth checking as it seems quite easy to get the wires caught when changing or inspecting the pads.
French car free zone....
mezuk04
I too suffered from this, a bit of bare wire was rubbing on the disc which was causing a lot of heat to be produced which partially melted the rubber connector block near it, causing great amounts of heat which could be felt as soon as you got close to the wheel and lots of nice burning smells.
Electrical tape and was all sorted.
Volkswagen Golf 59' 1.6TD S
Village
Simon,
I think its best if you do what Oily suggested as a starting point, you can check the wear indicator wire whilst you're at it as it seems that they can be a source of noise (me) and heat (Mez). If thats not the source of the problem, maybe its time for new brake discs and pads, I got all the parts for mine for less than 50 squid from a local motor factor (short notice) but I'm willing to bet (no money will change hands) that you can get the bits cheaper from GSF.
Not sure about heat effecting the wheel bearings, somebody else around here is bound to know.....
Pete
Pete
simoncanfer
I've cleaned and copper-greased the front brakes, which made little difference. I have also found one of the back drums was out of adjustment; one wheel was unbraked with the handbrake full on! So now I have better overall braking and so far have not noticed the grinding noise.
As for wires - "laugh out loud" - neither side has a complete unbroken set! I've never relied on them
Simon
Simon
