Hints tips and general help on changing fuel pipe
caveman_si
Unread post by caveman_si »
A mate just pointed out an oil patch on the floor by my car. after a long investigation and lots of smudges i ruled out oil, thought it was a loose sump plug as i did an oil change a few days ago. But after a root my car appears to be spewing fuel out from behind the engine. I cant tell if its either the fuel in or fuel return pipes but it is from the section of pipes that come up from the under of the car to the primer bulb, and then from the fuel pipe to back under the car.
So i think i might just replace them both.
So like the title says i need Hints tips and general help on changing fuel pipe as its not mentioned in the Haines bol and ive never done it before.
Car is a 405 1.9td 1995
cheers si
406 lx 1.9td estate
