i see its got a 65Litre tank is this including the reserve,not filled it up yet!
what sort of mpl will you get and does it actually take 65l , =£65 ! yikes to fill it up
thanks
Matt
It's not quite that bad, as fuel is 790g per litre. A full 65 litre tank weighs in at just over 50Kg which should make very little difference to fuel consumption.micitroen wrote:Working on the assumpion that fuel weighs in at roughly 1kg per litre why would you want to run around the country with the equivalent of another (small) passenger in the car unless absolutely necessary?
