Could any members tell me if the pump used on an HDi Hydractive is used on any other models or point me in the right direction for info on the different types used and on what?
Thanks.
Steve.
Hydraulic pump types
AndersDK
Pick one
(only 2 port 6+2 piston types listed)
4007.T2 HIGH PRESS PUMP
- POWER STEERING AND WITHOUT AIR CONDITIONING UNTIL RPO No. 06444
- INJECTION XU5JP AND WITHOUT AIR CONDITIONING
- INJECTION XU7JP AND WITHOUT AIR CONDITIONING
- INJECTION XU7JB AND WITHOUT AIR CONDITIONING
- INJECTION XU7JP4 AND WITHOUT AIR CONDITIONING
- INJECTION XU10J2 AND WITHOUT AIR CONDITIONING
- INJECTION XU10J4 AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445
4007.T3 HIGH PRESS PUMP
- INJECTION XU10J2 AND AIR CONDITIONNING
- INJECTION XU10J4 AND AIR CONDITIONING
4007.T4 HIGH PRESS PUMP
- INJECTION XU5JP AND AIR CONDITIONNING
- INJECTION XU7JP AND AIR CONDITIONNING
- INJECTION XU7JB AND AIR CONDITIONNING
- INJECTION XU7JP4 AND AIR CONDITIONNING
4007.T5 HIGH PRESS PUMP
- DIESEL XU UNTIL RPO No. 06444
- DIESEL XUD9 AND WITHOUT AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL XUD9 AND AIR CONDITIONING SINCE RPO No. 06445 UNTIL RPO No. 07260
- DIESEL TURBO XUD9SD UNTIL RPO No. 07260
- TURBO DIESEL XUD9TE SINCE RPO No. 06445 UNTIL RPO No. 07260
4007.T7 HIGH PRESS PUMP
- TURBO DIESEL XUD11BTE AND WITHOUT AIR CONDITIONING
- TURBO DIESEL XUD11BTE AND AIR CONDITIONING SINCE RPO No. 07445
4007.T8 HIGH PRESS PUMP
- TURBO DIESEL XUD11BTE AND AIR CONDITIONING UNTIL RPO No. 07444
4007.T9 HIGH PRESS PUMP
- TURBO INJECTION XU10J2TE
- INJECTION XU10J4R
4007.Y7 HIGH PRESS PUMP
- TURBO DIESEL XUD9TE AND AL4 (HP16) AND WITHOUT AIR CONDITIONING
4007.Y6 HIGH PRESS PUMP
- TURBO DIESEL DW10TD
- DW10ATED TURBO DIESEL
4007.Q9 HIGH PRESS PUMP
- INJECTION ES9J4
- INJECTION XU10J4R
- INJECTION ES9J4
Anders (DK) - '90 BX16Image
steelcityuk
AndersDK
My guess is that they differ mostly in mounting and pulley diameter.
They still have to supply the same amount of flow & pressure for powersteering - any model.
Dont know if there are different flow rates for standard/hydractive/activa models.
The pulley diameters accounts for the various average engine working rpm. I.e. diesels would have a smaller pulley to run the pump faster etc. This in turn affects the needed length of the aux belt.
slim123
There are only 2 x real differences in the Xantia pump.
1) 6 Piston pump as fitted to the early Xantia using a flow distributor valve in the steering, also refered to as a two pipe pump (1 X rubber and 1 x metal pipe)
2) 6 + 2 Pump, this pump is commonly used on all Xantia's since they got rid of the flow valve and fitted the anti sink system, the 6 x piston portion of the pump is used for the power steering only and the 2 x piston part is used to run the suspension and braking system, this pump is also referred to as the 3 x pipe pump (1 x rubber and 2 x metal pipes)
All of the 3 pipe pumps are the same internally, with the same flow rate and the same pressure 175- max / 2750psi for the suspension and 150- /2200psi for the steering.
The only differences between any of the 3 x pipe pumps is in the way that they are mounted, the pipe angles and the pulley size.
The 2 x pipe pumps were all the same except that petrol cars used a large pulley and diesel cars used a smaller pulley.
So going on that, is you can make it fit, it will work!!
Also, the XM used the 3 x pipe pump on the last run of the range, again the got rid of the flow distributor valve and fitted anti sink to the car.
Regards
Slim
Regards
Slim
AndersDK
steelcityuk
