My C5 will hit 5 years next year. Does anyone know if I can get away with waiting untill I hit the milage limit for having the suspension serviced or is it best to get it doen at 5 years?
C5 Servicing
mooseshaver
C5 Servicing
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
bencowell
mezuk04
Check the ends of the car to see how floaty the spheres are, if they are ok then thats nothing to worry about.
Check the colour and condition of the LHM (how long was the last change?), or it may be worth just changing and cleaning filters for good measure.
General inspection of pipes and such things should be enough if you dont have any symptoms.
Volkswagen Golf 59' 1.6TD S
mooseshaver
I've not seen the LHM. As far as I know its never been changed as its not supposed to need servicing for five years or I think 150 000miles. If I pull one of the covers off in the engine bay I can see a place to top up fluid for power steering, but the words suggest I shouldn't open it. Think it was something about decontamination?mezuk04 wrote:Check the ends of the car to see how floaty the spheres are, if they are ok then thats nothing to worry about.
If it is just a fluid change then that can't be to expensive. Getting Married next year and don't really want to be buying lots of spheres.
Gone cars.
Gone cars.
JohnD
- x 72
JohnD
- x 72
C5's don't use LHM. The hydraulic system uses LDS which is supposed to have a life span of five years. It's not quite as straightforward to change as LHM is on BX and Xantias. The reservoir is under pressure.mooseshaver wrote: I've not seen the LHM. As far as I know its never been changed as its not supposed to need servicing for five years or I think 150 000miles.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
mooseshaver
definitely a dealer job then.JohnD wrote: It's not quite as straightforward to change as LHM is on BX and Xantias. The reservoir is under pressure.
Gone cars.
Gone cars.
mezuk04
406 V6
Gents, the LDS isn't under pressure! How many times i've topped up the "steering" reservoir
On the new generation Cits, the LDS fluid needs changing every 5 years. I've only looked at it from a distant perspective on mine, but it doesn't seem to be difficult to remove the reservoir and empty it to change the LDS.
The filters, if i'm not mistaken, are built in the pump/acc. assembly, but any that are on the outside of it can be cleaned as regular filters.
To top up the reservoir, fill it up with LDS until it reaches the small opening on the big filler filter.
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
rod
c5 service
hi all,is it enough just to change the lds in the tank, or do you have to flush the system?
02,c5 exclusive. 2.2hdi 50000 miles
time for a laugh!
had a look at a suzi 04 4x4 hdi. good engine.
how much part ex???
would you believe £3k. for c5.
argh!!!!!
rodders 8)
rodders
c5,2.2 hdi exclusive
pug 106 xld
pug 106 xld
AndersDK
Hi rod -
how would you flush the system ?
There is no other way than lowering the suspension to have as much fluid returned to reservoir as possible. Then replace the fluid. You get at least a 95% new and fresh fluid in the system this way.
Bit like changing the engine oil. There will always be some old oil left in the engine.
Anders (DK) - '90 BX16Image
JohnD
- x 72
406 V6
Perhaps it is under pressure when the engine is running as it's shared with the PAS pump, but for all the times i've openned mine up to top up the fluid after switching the spheres at the front, i haven't heard even a smal hiss out of it. As long as the car is lowered and let alone for 5 minutes, the system will depressurize itself.
My record for changing the front spheres, from the moment i instruct the system to minimum height to citaerobics, is 10 minutes.
Francisco
rod
c5hdi servicing
thanks anders, will do that when time to change,
i am going to top up the eolys tank next week (i hope)
will post result when done.
still running sweet as a nut.
p s had the top off the lds tank to check level.
no problem experienced, perhaps it is only under pressure when the engine is running.
re particle filter.i am trying the haynes manual for a pug 406, from the library.
it appears to be the same engine and exhaust as the c5.
will let you all know when checked
rodders 8)
rodders
pug 106 xld
pug 106 xld
mezuk04
Re: c5hdi servicing
rod wrote:![]()
rodders 8)
LDS tank, GOOD!!!!!!
Who was the egit that said LHM, damn them egits!!!
