When fitting the new ones the nut just spins the bolt around. How do you tighted the nut without the bolt spinning?
Sorry if this is a bit obvious.
Many Thanks
Robert
Hi Malcolm,citronut wrote:i would have thought for the lower joint you will need to put you jack under the anti roll bar right beside the swivel pin nut leaving enough room to get your socket onto the nut,and the top one has an allan key slot in the end of the swivel pin as it is not a tapperd pin like most swivel pins are
regards malcolm
sorry i forgot you guys down under are working upside down and with revers gravity HE HE HEMandrake wrote:Hi Malcolm,citronut wrote:i would have thought for the lower joint you will need to put you jack under the anti roll bar right beside the swivel pin nut leaving enough room to get your socket onto the nut,and the top one has an allan key slot in the end of the swivel pin as it is not a tapperd pin like most swivel pins are
regards malcolm
Yeah, sometimes you might need to do that, but I found I didnt have any trouble at all - in fact the weight of the hub hanging on the bottom joint was enough to make it bind so I could tighten it as well...I only needed the jack to neutralize the load to insert the top bolt in the first place...
Of course over here everything near the road doesn't rust away like crazy
Regards,
Simon
