Just curious!
2.1td
Just curious!
deian
clearing it's throat?
i THINK i may know what you are on about, it's like something resonating somewhere for a second or so....
does it happen when you accelerate in the lower gears (1,2 or 3) and then come off the throttle ( just enough as not to put load on the engine) it makes this noise before the engine decelerates (engine slowing down)?
if so let me know
if so let me know
2.1td
Just curious?
Yes, I think that describes it pretty well. What do you reckon?
deian
I'm guessing a tiny hole in the exhaust somewhere, it upsets the resonation of the sound hence the noise you hear, of course that is just my theory, i've recently found a small hole near my catalytic converter too (see noisy turbo post).
Failing that theory, baffles in silencers can cause unusual noises related to engine breathing (out in this case), and i'm guessing the middle silences after the catalytic converter since the rear silencer would be more obvious and rattly.
So my suggestions would be to check your exhaust.
- x 1240
deian
AndersDK
deian
2.1td
Crikey Anders!
Crikey Anders, your BX has certainly piled on the miles! Even though '93 was the last year (L reg' estates?) BXs were sold I still see quite a few soldiering on with big mileages. My brother has a really tidy '93 Xantia 1.9TD VSX which has done 206,000 miles on the same engine and box. Testament to just how good these cars are... IF they are well maintained! I am convinced that the vast majority of perceived problems with these fabulous Citroens are down to either owners just not bothering to do anything to the car until something goes wrong (and then moaning!) or getting someone who hasn't a clue what they are doing to tinker with their car. Surely this applies to any car not just Citroens?
Be careful!
deian
