We own a Citroen Picasso and would love to interface an MP3 player to it
The Picasso radio has a facility for a CD changer in the boot which means there must be audio leads from the boot to an input on the rear of the radio, selected by pressing the changer button. So why can I not find information on how to interface to it? All I want is to add a 3mm jack socket on the facia somewhere.
Has this subject been aired before? No search of the site picks it up. I can find plenty of I-Pod adapters at over £100, but I do not have an I-Pod (nor want one) and this cost includes controls for the I-Pod from the steering wheel buttons.
Can anyone help?
MP3 Connection for Picasso
Gammy leg
David,
If you have a Cassette Radio in your Picasso you can play your MP3 via the cassette player. Just buy the adaptor from Argos or similar, plug the jack into your MP3 and the cassette into the cassette player. Just check the head configuration of the adaptor cassette, some seem to be mono only.
You can also route a portable DVD through your sound system.
HTH
Gammy
HTH
Gammy
David Baars
Thanks to both.
We have an SX with CD player (and an older version which does not play CD-RW), so the cassette adaptor I'm afraid is a non-starter. Actually I have one of these which I use in my Kangoo van and the result is hissier (sic!) than any cassette.
I also have an FM transmitter (which I never use of course). But if I did I suspect the result would also be very "hissy". We are off on a trip to the south of France in a few weeks and I think that listening to the result for a good number of hours would be quite wearing.
What we listen to is not music, I would have no problems using CDs because you listen to them over and over. I record plays, comedies and plays from the radio and once listened to the CD is thrown away - quite a waste.
Thanks DB
Thanks DB
mezuk04
David Baars
Ross_K
- x 110
You can get mp3 player -> cd changer adaptors, but they're only available for ipods. The good thing about them is that you can retain your steering wheel controls.
You've ruled out the cassette adaptor and the FM transmitter, so your options are limited.
Your choices would be:
- 1. mp3 CD head unit
2. cheap ipod and cd changer adaptor
john stenhouse
jgra1
- (Donor 2021)
- x 36
same for me John.. I have fitted the older Xantia unit in mine for this reason.
Dave, there was some postings on this a while ago.. I really cant remember what the concensus was.. I wanted to do the same as you, i.e. 'tap-in' to the cd changer wiring.
buy a used Sony unit, this will have MP3 access from front via jack, and work with steering wheel controls. (subject to an audioline etc connector)
For the Xantia its a DX300 or higher, form memory.
the other good thing about front access
is that you could plug a DVD player's audio into it... if you want to hear monty python blasted all round the car that is
John G
John G
David Baars
8304
i bought a head unit with cd disk changer plug on the back it also came with a module box so i can plug my ipod in directly. It works well with all the playlists / song names etc comming up on the head unit screen.
if you have a cd changer input as previously mentioned you could do the same but you will need to check that you head unit has two pre - out plugs on the back as the ipod module box will need to plug into those
its also got an 800w amp (very imature i know) with a decent set of speakers so you can feel the music as much as you can hear it!!
hope that makes sense!!!!
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
drpau
Have you pulled out the cd player to have look on the back? A lot of cd players/tapes used to have two phono jacks on the back for left and right channels - you can get a phono to 3.5mm lead and wangle it through to the passenger footwell- job done. All depends on wether or not the Citroen cd player has any phono connections on the back...
http://www.maplin.co.uk/Module.aspx?C=S ... leNo=48366
You can get longer ones than this obviously...
Paul
Paul
99 Xsara SX HDi 105k with PSi power box- smokier but well worth the wonga!
