HDI 90
les m
HDI 90
Unread post by les m »
hi all
I have a problem with my clutch peddle some times it sticks half way
down especialy when in traffic in town
the car still drives ok and if i put my toe under the peddle it will come back up
what is the return mech on the clutch ? spring or other
the car is 2ltr HDI 90 lx estate on a W plate (2000)
AndersDK
Unread post by AndersDK »
As this could be wear related - please dont keep your car's mileage as a secret to us 8)
Anders (DK) - '90 BX16Image
les m
120k
but all serviced up to date
and the garage could not find the problem :shock:
AndersDK
When a clutch wears - it does so by the release bearing grooving into the clutch spring fingers.
On releasing the clutch - the release bearing is catched in the grooves and now held by the finger springs trying to return. The pedal is then held down by its weight - as there are nothing else to push it back up
In most cases the bearing will eventually slip no big problem - and the whole thing is mostly felt as a "notchy" clutch pedal - with a weird "hard point" just before the bite point.
But this depends if the clutch is the pull or push type - referring to how the release bearing acts on the clutch finger springs.
Because all PSA cars are born as LHD's - the clutch cable takes an unwanted querky route from pedal to clutch on RHD cars. This in turn makes for some strange symptoms on a worn cable. The inner cable will tend to groove into its outer part - making the cable stick.
I cant say what exactly applies on your car. But I'd certainly try the cable as first call. At 120Kmiles it would not be a waste - should it be a later clutch job that is the solution.
That is - if the cable has not already been replaced :wink:
les m
thanks for the prompt reply :D
Homer
x 16
Unread post by Homer »
Will the HDi 90 be a cable clutch or a hydraulic one like the Xantia HDi?
rossd
Unread post by rossd »
HDi 90 in the 406 has a hydraulic clutch :)
2003 Xsara HDi 110 - Commuting Hack
http://www.rossy.org.uk/ - 205 Track car progress
easterroad
Unread post by easterroad »
An occasionally sticking clutch could be down to somethng simple like the pedal getting stuck on the carpet....... has happened to me before :wink:
