It wont work . I hit the button push the slider to 18c close windows ,
outside temp 85 !!! and nothing happens it just blows out cold air , the
same as before i hit the switch . A sticker on top of the unit tells me it
was serviced last June . A comp relay was changed and it was charged full .
Has it broken down again , if so can i mend it or is it a garage job .
Xantia 1.9 TD air-con issue
citroenxm
- Fallen Hero
- x 70
Clogzz
- x 40
Looks like a bodgie on the compressor clutch or cabin switch that causes the air conditioning to be on all the time.
The aircon switch should cause the light in its centre to come on when turned on, and the compressor clutch should click on loudly soon after.
Maybe try going back to the June man to see what he knows, and what warranty the law provides.
2002 C5 2.0i AL4 239,000 km 76372389
