2.0i Turbo Activa MPG
LeeDJC
Unread post by LeeDJC »
I'm thinking about buying one of these. Have seen one, but whats the MPG like? I'm guessing at aroung 25 urban 30-35(maybe) on a run?
It's a 1997 model, so is there anything common which gives these ones grief?
2004 Berlingo Multispace HDI, 105000
stevieb
Re: 2.0i Turbo Activa MPG
Unread post by stevieb »
LeeDJC wrote:I'm thinking about buying one of these. Have seen one, but whats the MPG like? I'm guessing at aroung 25 urban 30-35(maybe) on a run?
I have a 406 2.0 turbo (same engine as the Activa).
My turbo let go around 100,000 miles. Replacements are expensive.
I get around 32mpg out of it, even when thrashing the *rse off it. My driving is completely mixed, so I can't really comment on long runs vs town driving.
It goes like stink, and upsets a lot of rep-mobiles. Puts a smile on my face every time.
Quackers
x 17
Unread post by Quackers »
From a full tank in both activa's i have had i get between 350-400 miles. Thats with aircon on too. You can get 40mpg if you stick at 56mph on the motorway (never doing that again!) Just expect an average of 28-30mpg.
KP
x 27
Unread post by KP »
Lots of people convert to LPG and there are a few knocking about as well already converted that i know of.
The turbos can be expensive but it depends how badly they go. if it lets go and you dont notice it will bugger the core and thats the pricey bit but if you keep your eyes open to the signs the turbo is on its way out then you could easily half the cost of it being repaired as often the seals can be replaced when the first warning signs of failure kick in :)
deian
Unread post by deian »
i don't understand why the turbo's go on them, they are low pressure after all, you will often hear about the 2.0 turbo refered to as CT (constant torque), it isn't a turbo to get massive accelearation really, it's there to keep the car going around corners (as you know, never come off the throttle on corners) therefore taking advantage of the activa suspension, and also for overtaking smoothly, a Xantia V6 would get similar fuel consumption and has 194bhp compared to 150bhp, and probably hydractive 2. I'd guess the V6 would eat an activa for breakfast.
Kitch
Unread post by Kitch »
Every Activa I've owned or driven took the p**s with fuel. Shame, because everything else was great.
If you drive it very very lightly I imagine they'd do ok. But I couldn't dawdle around in it, so it drank!
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
DoubleChevron
Unread post by DoubleChevron »
Hi Guys,
yeah your not getting great fuel economy .... However I guarantee the 2litre slugomatic petrol Xantia will get much the same fuel economy with a tiny fraction of the power :( You can't expect much better with a small petrol motor dragging around a heavy body (after all it weighs nearly as much as a CX !!).
seeya,
Shane L.
'96 Big BX 2.1TD exclusive slugomatic (aka XM)
'85 CX2500 GTi Turbo Series II (whoo hooo)
'96 Xantia VSX slugomatic (sold !!)
and of course, lots of old Citroens, slowly rusting away in pieces ;)
KevMayer
Unread post by KevMayer »
My Activa returns 5.5 miles per litre more or less spot on. So If I put 30 litres in I can almost guarantee that I'll get 30x5.5=165 miles out of it.
If I take it easy I have got 6 or 6.5 miles per litre.
by the way. 1 gallon = 4.546 litres
5.5 x 4.546 = 25 mpg - my usual fuel consumption
6.5 x 4.546 = 29.5 mpg - taking it easy fuel consumption
The Activa is a pleasure to drive which outways in many respects the poor consumption.
cheers,
Kev
Cheers, Kev
njr
Unread post by njr »
I dream of the day I can break 300 miles from one tank of fuel. My last check was 22 mpg :shock: which was 267 miles. It is definitly the worst thing about the car.
03 Renault Master Dci 70k miles
02 406 HDi 110 65k miles
njr
Mines a 97 I think and have had no real problems with it a part from a burst LHM pipe in the centre of Toulouse, which could have been any Xantia.
If its as a main driver I personally would have a HDi any day, though a 97 activa is probably only worth 500 tops so that would save plenty for petrol.
Quackers
x 17
njr wrote:I dream of the day I can break 300 miles from one tank of fuel. My last check was 22 mpg :shock: which was 267 miles. It is definitly the worst thing about the car.
You got your foot on the floor all the time? :shock: I have NEVER in the last year had less than 320 miles out of a full tank, and that was flooring the car. I'm going london, the dover and back home in next few days (from staffordshire) and i should be able to do that on tank and a half if that. Somthing is wrong with your engine. What fuel u putting in? Supermarket? Esso? BP?
njr
I dont hang around :wink: and the roads over here have ten times less traffic but even so. I put in french supermarket 95, and service the car as per the book.
Quackers
x 17
Have you tried putting in non supermarket 98 RON? The manual for my Activa says 98 RON is what it should be running on.
Rostami
Unread post by Rostami »
hummm...it looks like there were no HDi Activas sold in the UK. Am I correct?
My Hdi can do around 1200km on a full 70 liter tank of diesel, if I do not go faster than 120km/h...
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
x 1434
"hummm...it looks like there were no HDi Activas sold in the UK. Am I correct? "
Yes :evil: . If it weren't for the 2.0 Turbo's exspensive drinking habit, I'd have an Activa :cry: The difference in fuel costs for me between that and an HDi is about the cost of a reasonable TD - per year!!!
