Which flare nut spanners?
steelcityuk
Unread post by steelcityuk »
I'm going to buy a set of these, probably from Machine Mart. Is there a particular set of sizes I need look out for?
Thanks.
Steve.
not applicable
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Sadly 8mm and 9mm will be most useful for citroens, try snap on but be ready for a slight shock.
Stewart
AndersDK
Unread post by AndersDK »
Only go for hexagonal types. 12edge will round the flare nuts first attempt.
Anders (DK) - '90 BX16Image
steelcityuk
Thanks for the info. I bought a couple from Halfords. Lifetime guarantee, hexagonal type about £4 each.
Steve.
not applicable
x 94
Unread post by citronut »
dont wast your dosh on cheap ones as there jaws spread then round of the nut,snap on are the best i have eever used,but they are not cheap
regards malcolm
Stewart(oily)
x 35
Did you find the sizes I suggested at Halfords then? I have used some of their tools and they were okay for quality.
Stewart
slim123
Unread post by slim123 »
A normal spanner (open end) will grip the points of the hex, a bi hex flare spanner will also do this, this aint much good on a hollow pipe fitting. A mono hex flare spanner is best, as this will grip the flats, or I have allways found that a snap on open ended flank drive spanner to be better than any flare nut spanner.
If the snap on flank drive wont do it then it's cut the pipe, use a mono hex socket and then make a new pipe.
Also I find Halfords tools realy good quality, unfortunatly the guarantee dont cover loosing them!!!
Regards
Slim
steelcityuk
I bought a 'full' set from Halfords which are 9&11mm, 10&12mm, 13&14mm and 15&17mm. I used the 9mm to change the anti sink sphere a couple of nights ago. I've always liked Halfords spanners from the time I was bought a set of their ratchet spanners several years ago, I find the sizing to be accurate, they're strong and the polished chrome finish means they're easy to keep clean. Sounds as though I need to source an 8mm one though.
Thanks for the suggestions.
Steve.
not applicable
slim123
Buck & Hickman do a flare spanner, 8mm one end and 10mm the other, they are on line or have braches all over the place.
A quick google around should find the nearest to you.
Regards
Slim.
