Hi all,
I have a '97 1.9td estate on an r plate.
have been checking the water recently, and if definitely losing some along the way, so thought it was similar to my bm, and decided to get a new header tank cap, just incase it was steaming out of there?
Car is still losing water, no overheating, no obvious signs of leakage i.e. antifreeze mark, or spots on the driveway in the morning, so my only consclusion is that it could be "steaming" out of somewhere when the system is pressurised, which incidentally it does do.
Can anyone shed any light on potential areas where this could happen, or could it be the water pump leaking maybe???
Thanks all,
Steve
Xantia Losing Water!!!!
AndersDK
Have you ever got the coolant level warning light ?
If not - its likely you worry about the empty space needed in the header tank for the coolant to expand when it gets hot. Also on releasing the cap at cold engine if you get a small fizz from escaping pressure there are no leaks in the system.
Anders (DK) - '90 BX16Image
KP
- x 27
- x 1430
wrinklet1
Idea,
if you have a vent cap on your water system (near the offside engine mount) on a small pipe, with the engine cool, remove the pipe and connect a foot pump or electric pump and put a bit of pressure into the system about 10psi, you should find a leak that way if you have one. It may be at the bottom hose on the radiator, it was on my xantia.
Paul
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
- x 1238
wrinklet1
When your driving the car, if water is leaking from a pipe, it may be evaporating when it hits the hot engine. I doubt its the head gasket. Do the pressure test as I have said. I had the same problem with my car, no water on the drive or water showing. It only displayed itself once under pressure.
Paul
PS try it, its cheaper than changing the head gasket
Paul
8304
about the 10psi pressure test - surely the coolant system is under massivly more pressure when the engine is hot and running and so this would show up the leak??
i know the engine heat might make it evapourate but tere would be some sort of sign of dampness.
10psi isnt much pressure - squeeze the top rad hose when the system is hot and its really hard....
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
AndersDK
Ahaa ...
But the rad cap valve opens at some 1.5bar (21psi) pressure - no matter what pressure the hot cooling system develops - it will be releived to a max of some 21psi. (the valve does of course have some hysteresis)
The cooling system is kept pressurised in the first place to raise the boiling point. This is to avoid the coolant boiling at "hot spots" in the head and around the cylinder tops.
If the coolant starts boiling - the cooling effectiveness is lost almost 100% in spots
Note that raising the boiling point has nothing to do with temperature and cooling : i.e. the temperature can still go high. The coolant just wont boil.
Homer
- x 16
- x 1238
Robin
The 1.9TD engine block has a housing on the rear offside only accessible with the drivers RHD wheel off. This housing has a capped off pipe stub which only leaks when the system is under pressure. It is a rubber cap retained with a clip. Easily replaced costs less than a quid but what a relief when you find it!!!!
I was convinced the head gasket was on its way out.
Check it out first. Robin
Citroens are dedicated to those who take a big bite - and just keep on chewing!
320i coupe
thanks all for that, sorry i havent replied!
i can definitely confirm its losing water from somewhere, although theres no scum & the car isnt overheating, as i do drive in quite heavy tarffic sometimes, plenty to be getting on with, so i will keep you all posted, but of anyone has alternative suggestions, please post them here as i want as much to go at as i can, and leave no hole unturned!
steve
steve
oscarloco
dnsey
- x 19
