can someone go out to their TD Xant, Pug, ZX etc (1.9)
lift bonnet, grab intercooler,
and try to 'rock' the engine...
see my post about dangerous ZX.. I can rock my friends about 10-15mm and wonder if anyone else can do likewise.. I am trying to prove Gearbox mounting is bad (have changed lower center mount already)
it will only take a second
John G
can anyone do me a very small favour?
So you think you can get about ½ the world's population out there and rock their engines
John -
There is NOT supposed to be that movement of course - thats logic 8)
The engine should feels firmly attached to the engine bay with a wee slight hard rubber "feeling". I.e. you CAN actually rock it a tiny bit if you are violent.
You have an engine rubber mount replacement job ahead. A common and cheap job on any elderly car.
John -
Anders (DK) - '90 BX16Image
- CitroJim
- x 6204
- Contact:
Well I cannot on my Xant TD as it has its intercooler mounted in front of the radiator..
But yes, I know what you mean and NO, there is no way the engine should move that much. Something is very bad if it will move around that much..
A duff gearbox mount, I would have thought, would only allow the gearbox side of the engine to move around.
Is the locating bracket for the lower mounting intact to the chassis?
are both the lower stabaliser bolts tight,as the engine hangs from the two top mount its unlikly your problem is there,and the drive shaft will be anbsalutlynotting to do with it,also i have seen a BX with the lower mont bolt holes very oval so even though the bolts where tight it still alowed lot of movement
regards malcolm
regards malcolm
it is silly to dismiss the driveshaft as having nothingto do with this problem.
it doesnt seem logical that a joint, however worn like a tri - ax joint should produce this side to side motion but they do. I dont know why a worn tri - ax does this but they most definatly do.
i had the same problem on my car and spent the best part 8 moths changing mounts and suspension bits etc to find it was a worn tri - ax joint on the short drive shaft.
the fact that the grease has leaked out of yours points even more heavily at it being this....
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
one daft idea i had was to drive up a hill without a bonnet
maybe i can see the engine rocking,...
can always play some metallica as well and see if that makes it rock...?
ok.. all replies so far gratefully received
the fact that the gearstick moves as the wobble occurs means the gearbox is moving, despite whatever is causing it... so the mounting can;t be all that good anyway..
