hello. i think my compressor has gone tits up as the clutch started to rattle then funny smell then the aux belt snapped. does the aux belt from a non air-con car fit mine so i can bypass the compressor.
thanks
toby
2001 406 2.0 HDI 90
Aux belt ???
AndersDK
Dont think so -
The non-a/c belt must clear the compressor pulley and probably at least one extra idler wheel.
The aircon electric clutch should not activate if you set the aircon off ?
If the compressor suddenlygets so hard to pull that it burns the belt - the a/c system must have a leak.
Anders (DK) - '90 BX16Image
meonk
thanks anders..... i think its my fault, i have been running a 12v feed to the comp. so its been on when ever the car was on but i think the clutch was week and it wor out and started to rattle and it made the pully verry hot and i think that made the belt snap.
can i take the clutch off and leave it like that.
thanks again
toby
thanks again
toby
AndersDK
I believe you will have to undo the compressor completely to clear it from the belt run.
The electric cluctch would be a pressfit onto the compressor axle.
Cant see it as a big problem "converting" to a non-a/c.
Usually a cool beer and a thorough visual inspection of the affected area of the belt run will make things clear - try it 8)
