does anyone know the tightening torque for the crank pulley and the water pump bolts ?
I have a Citroen Synergie with the 2.0i 8v engine XU10J2 that is the same as fitted into the 405 and the xm
I've got the water pump in but not sure what torque to do it up to
crank pulley tightening torque ?
Mosser
2002 Peugeot 806 quicksilver HDI with bosch ecu
Mosser
JohnD
- x 72
Mosser
Eeek !!, i've got an iron block, hope the water pump bolts will be ok !
Its all done now, just about to start it so I will know in about 10 minutes !!
Intersetingly, My block is marked as a J4E block, and i though that was supposed to have a 16v head ?, I have double checked and i definatly have a J2 head on this block
