Do I have a language problem here ?
http://www.citroen-pr.net/catalogues/il ... 711150.gif
If we are talking the right hand (UK drivers) side long driveaxle support bearing (item 6 in above schematic) on the engine block - then stop your search.
This bearing is an industri standard bearing - fitting all PSA's :
6006 ZZ (code ZZ = dust covers)
My guess this bearing can be found at some £5 in machinery shops
However the bearing locator clamp ring (item 7 in above schematic) must be purchased at Citroen (or Peugeot) :
3248.08 DRIVE SHAFT BUSH Dkr95,90
Fits all PSA transversal engines with a support bearing for RHS drive axle.
KP :
Please refer to the schematic above which item you are talking about ?
