So it looks like as the months go by the offside h/brake becomes less and less effective.
I have looked in the Haynes manual; i can a pic of the cable clipped onto the side of something (is this the adjuster) which is held into the caliper.
Could it be worth pushing the piston back into the bore, to unfree it?
surely if its passing the mot something is seizing in the preceding months prior to the mot.
The nearside is fine, it click on around 3/4 click tight on a level surface. if it helps i took the car for a quick check on a rolling road, the n/side was 250kg, offside 5kg, pass was 150kg (quoting from memory so may be wrong)
