Squeeeling on start up
Jshodgson
Unread post by Jshodgson »
Hi all
when I started my Xantia today there was a really bad squealing. The STOP light stayed on for much longer than usual as did the battery light. I drove to work (21 miles) and the squealing only stopped when I went above 30mph. Even when hot at the end of the journey it still squealed when idling.
I looked at the alternator and belt and the belt is very slack (moves about 10-15mm) the alternator also moves slightly. I tried to tighten the belt but some stupid bugger has rounded the allen key nut on the adjuster so I can't. I tried some mole grips but with no joy.
I then slackened the upper alternator mounting nut and could move the entire thing!! I was expecting a mounting point at the bottom aswell?!?!?!?
I tried to rotate the alternator to tighten the belt and see if that stopped the noise but I think with the force of the belt it just moved as the squealing continued.
Any ideas or suggestions on what to do next?????????????
Had (Saxo VTR 1999 (T) LPG converted - do not ask!!!)
Had (Xantia LX TD 1995 (M) 144,000 miles)
Had (Xantia TD Estate (N) 147,000 miles !)
NOW GOT Picasso 2.0HDi (02) 96,000 miles
x 94
Unread post by citronut »
sounds like a bolt is missing,
regards malcolm
x 1237
Unread post by Peter.N. »
Yep, and the squealing willl undoubtably be the belt slipping.
Jshodgson
any suggestions for adjusting the rounded nut?
James.UK
Unread post by James.UK »
Replace it.. If you cant get it undone take it to your local garage, they will do it for a small charge.. :)
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
Jshodgson
I have used 4 new bolts (found that there were others missing!) and now the belt is much firmer and does not squeal. As the adjuster is unuseable at the moment I could not fine tune the tension in the belt and I am left with about 3-5mm of movement when I press it.
Is this too tight?
Are there any potential problems if the belt is too tight?
AndersDK
Unread post by AndersDK »
The alternator shaft bearing is designed for this during its service life. I'd say there is a larger risc the idler (tensioner) wheel bearing will wear out first - if the belt is too tight.
I doubt you've got it too tight - unless you are a blacksmith 8)
Enjoy your work - and your car :)
Anders (DK) - '90 BX16Image
kip
Unread post by kip »
I had a noise that I thought was the hydraulic pump. It also caused some squealing on startup.
Eventualy it turned out to be the Idler.
The whole thing disintergrated with an imbaressing amount of smoke in peak hour traffic.
I was able to replace the bearing with a $5 bearing from the local bearing supply shop. That and a new belt.
Jshodgson
After tightening the belt there is still a small squeal on start up which goes once the enginge has been revved. After my previous diagnosis and work what should I check next?
x 94
adjust the belt tention up a bit more as these ribbed belts need to be very tight compared to the old V belts,you will be suprised how tight they have to be,but only adjust a little at a time until it stops squeeking
regards malcolm
rmunns
x 9
Unread post by rmunns »
The easiest solution I've found is WD40. Instant cure!
Jshodgson
roger what did yoou do with wd40?
AndersDK
Jshodgson wrote:roger what did yoou do with wd40?
Bet he sprayed it on the belt. Works a treat - for a week or so :wink:
The idea is to treaten the belt rubber to make it softer and then grip better. That prevents the belt from squealing.
Better still is to use a silicone spray - the type used for door rubber lists etc. Makes the rubber surface much softer.
In other words - if the spraying instantly helps - you need to have the belt tightened a bit further.
