Oh Bugrit- after 90,000 miles the clutch on the C5 (2.0 HDi) is starting to slip when booting the throttle, overtaking for instance.
Usual symptoms, revs rise but speed doesn't increase, then after a few seconds the clutch bites again.
As I've got to have the cambelt changed soon, I'm wondering if it would be best to get both jobs done at once if my credit card can take the strain.....
Apparently doing a C5 clutch is not a nice job!
OTOH I could try and eke out the clutch for a few more months but I'm wondering how much longer its got left before giving up the ghost altogether, especially as I do quite a lot of towing.
Opinions anyone?
My slip is showing.......
JohnD
- x 72
- x 94
it shouldnt make any odds doing either one at a time or both together,as they are both a opposite ends of the engine,unless they have got to remove the engine and box complet for the clutch job,in this case it will be best to have both jobs done together,as far as how long will the clutch last there is only one way to find out and you will be the first one to know
regards malcolm
regards malcolm
alan s
- RIP 2010
- x 6
I know I've got a twisted sense of humour at the best of times, but I found this more than a bit amusing.
I won't ask if there's any connection!!
Alan S
as it appeared in the forum index.My slip is showing.......
Got rear ended !!
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
- x 1238
The more you let the clutch slip the quicker it will wear out. If you use some restraint with the throttle it could last a long time, my last XM had this problem, slipping when the turbo came in, but by backing off a bit and letting it bite, it lasted until I parted with the car some 10k miles later and was still quite driveable then.
PowerLee
Sir Clive
Well, I don't have any intentions of parting with the car just yet- its hardly run in
Is the dual mass flywheel really *that* troublesome? Certainly mine emits none of the warning squeeks when taking up the drive........
Is the Valeo kit cheaper than the Citroen OEM part- silly question I suppose
Though I do wonder what the problem is, given that I have never managed to wear out a clutch in any of my previous cars, the BX one was still going strong when I sold it at well over 200,000 miles, and the Visa diesel did nearly 150k before the release bearing broke up.
JohnD
- x 72
[quote="Sir Clive"]
Is the dual mass flywheel really *that* troublesome?quote]
It sems that when they do decide to go, they go in an expensive way, having done a lot of damage. Reading other forums, other makes of cars with DMF don't appear to be any more reliable than PSA. Also, I believe it's Honda that's gone back to fitting a solid flywheel.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
sub42
Yep!
Seems Dual Mass Flywheels are prone to failure. The worst case I havwe had was on my VW Transporter T4. The beginning of the end was marked by a rough idle, and chattering back down to idle from part throttle. It had a new clutch and flywheel at 8k, 20k, 50k, and finally 95k! When the job costs £795 a time you can see why the lease company was trying to blame me! As it turns out DMF's are a liability that VW have agreed cause problems on that particular engine configuration. I test drove about four 2.0HDI Synergies before i bought my 1.9TD, and to be honest, the gearbox noises some where making worried me lots! So, on balance, I thought that mine at 50k, with history, would be a better buy than a 120k mile HDI with some history, and a price tag about at £1.5k more.
Previous convictions for ferret and giraffe rustling.
Synergie 1.9td SX loaded spec.
