For some time now, the starter has been slow on this clio. It has had a new starter, new battery and alternator. Now, it won't start at all.
The ignition switch seems ok as all the lights etc work as they should.
I have noticed when poking around that a pink wire with a spade connector near to the alternator isn't connected to anything. I've also noticed that there is a pink wire going to a contact on, what i assume is the starter relay, behind the battery.
Is this the problem? If so, wherer should this wire be connected.
Cheers,
Lee
1.9D 1994 Clio Starter problem
LeeDJC
2004 Berlingo Multispace HDI, 105000
