Hello again,
Following on from my 110 bhp HDI C5's lack of turbo boost I have switched my investigations to the vacuum pump as, according to my neihbourhood mechanic, there is not much vacuum at the wastegate. There is just enough suck at the disconected pipe to feel it, it hardly pulls your skin off!! Anybody know how much vacuum there should be? The exhaust blockage suggestion has been ruled out, by the way.
Many thanks,
John.
C5 2.0 manual HDI ESTATE - NO UMPH!! - Possible Solution !!
johnway
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
pugxpert
johnway
OK thanks - now if I only knew where to find it - what I would give for a workshop manual !! Any ideas?pugxpert wrote:your turbo is controlled by vacuum i would check your turbo control soleniod first,dont think it's your pump they are quite reliable
John.
- x 1043
if you remove the cover over the n/s/f sphere you will find 3 electrovalves one is for the turbo wastegate & the other 2 are for the EGR valve & the EGR throttle butterfly.follow the pipes to see which is which as they are all identical (which means you can swap them around for testing
). also check that the pipes are clear by blowing through them with compressed air. i think the vac pump should draw 0.8 bar but as already said they are quite reliable.
johnway
Brilliant help - thanks very much !! I shall have a play tomorrow. If I can't figure out what is going wrong I shall try a local Bosch agent - found one not too far away who advertises himself as a Citroen specialist. If it turns out to be something simple then that will be one in the eye for the Citroen dealership!!wheeler wrote:if you remove the cover over the n/s/f sphere you will find 3 electrovalves one is for the turbo wastegate & the other 2 are for the EGR valve & the EGR throttle butterfly.follow the pipes to see which is which as they are all identical (which means you can swap them around for testing). also check that the pipes are clear by blowing through them with compressed air. i think the vac pump should draw 0.8 bar but as already said they are quite reliable.
Regards,
John.
johnway
SOLUTION FOUND !!
Hello all,
Thanks for all suggestions - especially those advising a Bosch specialist. I visited my local garage who have Bosch diagnosis equipment and the problem was quickly eliminated: a plastic pipe to the wastegate had touched the manifold at some point in time, melted a hole and sealed itself!! 4.5 hours of scratching head by a Citroen technician and 30 mins of investigate and repair by the local mechanic - guess which one I'll be using in future? C5 now back to its' former glory.....VROOOOM!!
Regards,
John.
Regards,
John.
bencowell
johnway
I am doing so already!! Lots of go and aircon - a super driving experience.bencowell wrote:I'm glad it was sorted out quickly and easily. Go out and enjoy it!
Regards,
John.
