I have a N reg Xantia 1.9TD with aircon.
Can anyone supply or upload a link to an accurate circuit diagram for the cooling fan circuits. The Haynes manual is worse than useless, and searching this forum has only brought up the Peugeot 306 diagram.
Exect
Cooling Fans
I don't know if the N reg is pre-facelift (<-98 ), so i got this schemes for one, on citroen-pr.net, with the XUD9TE engine (the other options were the XUD9D or XUD9SD)
As they are in *.bmp format, they are bit big.
http://classicotuning.no.sapo.pt/xantiacoolingfan2.bmp
http://classicotuning.no.sapo.pt/xantiacoolingfan1.bmp
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
If you've got the time, could I suggest you take a peak here as it sounds very familiar.
http://www.frenchcarforum.co.uk/forum/v ... sc&start=0
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
That is exactly what that thread is about, the radiator fans and their operations.
This is another along the same lines:
http://www.frenchcarforum.co.uk/forum/v ... 90&start=0
This is the thread that gives the info on the internal fans:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17322
Alan S
Alan S
RIP Sept 19th 2008.
