C5 alarm plug
406 V6
C5 alarm plug
Unread post by 406 V6 »
Chaps,
Do you know where the alarm plug on the C5 is located and its pinout?
Thanks :D
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
x 1043
Unread post by wheeler »
on a LHD car the plug is located to the left of the steering column up behind the dash,its a 12 pin blue connector.
Whats the problem ?
406 V6
I want to install an alarm on her, got a good deal on one and will probably save the installation money by wiring it myself. Usual stuff :)
Francisco
PowerLee
Unread post by PowerLee »
406 V6 wrote:I want to install an alarm on her, got a good deal on one and will probably save the installation money by wiring it myself. Usual stuff :)
C5 is CAN!
You need an alarm that's CAN compatible!
406 V6
http://www.peugeotclubeportugal.com/top ... Vende%2Dse
The guy who's selling it is a friend of mine, and has successfully installed one on his 2004 206 1.4HDI. As CAN is CAN and doesn't mind if it's installed on a C6 or a C2 (the wiring is basically the same anyway) i was considering giving it a chance.
Francisco
x 1043
You can fit just about any aftermarket alarm to multiplexed cars without any problems at all,as long as the person installing it does it corectly.
i dont think it will be any good to make your connections at the alarm ECU plug,all you really have there is battery live,signal to siren,input from ultrasonic deactivation button,earth & bonnet switch wiring.all the rest of the info like indicators,doors open & central locking comes to the alarm ECU via the VAN network as digital signals so you cant take this info from there.
On the C5 you can pick up most of the wires you need for alarm installation at the BSI.
