Bouncy Rear suspension
Post Reply
alanar
My Cars:
Post by alanar »
I have just purchased a 1995 Xanta 2.0 16v VSX. Car drives really nice however there are a couple of problems hopefully someone can help me with.
1. The rear suspension feels really floaty when going over bumps, All other suspension works ok and car rises and drops when it should.
2. The Heater fan does not work but there is a soft buzzing noise from behind dash
3 Electric Mirrors do not work at all. All other electrics work perfectly.
Hope somone acna help.
Alanar
fivelighters
My Cars:
Post by fivelighters »
just a thought y did u buy it :shock: :shock: :shock:
Clogzz
My Cars:
x 36
Contact:
Re: Bouncy Rear suspension
Post by Clogzz »
:mrgreen:
It then would have air conditioning ? :?
If yes, here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17322
If not, it’s still the ignition switch, or this speed-regulating resistor is open:
2002 C5 2.0i AL4 230,000 km 76372389
alanar
My Cars:
Post by alanar »
I bought it because its a very nice car!
Yes it does have aircon. Took a look at that thread and that looks a bit complicated for me to try Thanks.
:cry:
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1204
Post by Peter.N. »
You've got bouncy and floaty suspension? Normally two opposite causes. Its bouncy if the spheres are flat but to be 'floaty' they must be good but possibly the wrong type.
alanar
My Cars:
Post by alanar »
Definatley bouncy, If I go over a speed bump then the front is ok but the rear will bounce at least twice.
Mandrake
My Cars:
x 665
Post by Mandrake »
alanar wrote:Definatley bouncy, If I go over a speed bump then the front is ok but the rear will bounce at least twice.
If you try to push the rear suspension down by hand is it stiff or soft ? (You should be able to nearly bottom the suspension just by pushing by hand)
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
My Cars: Currently:
x 1204
Post by Peter.N. »
As Mandrake says. There should be about 6" of movement on each wheel, if none or very little, requires new spheres. Assuming it is riding at the correct height i.e. not resting on bump stops.
alanar
My Cars:
Post by alanar »
I went to check it this morning but was peeing it down so just got in and drove away. Funny thing is this time by the end of the 25 min journey rear suspension was working perfectly.
My Cars: Currently:
x 1204
Post by Peter.N. »
Sticking height corrector valve. Squirt several applications of WD40 on the linkage.
alanar
My Cars:
Post by alanar »
I have checked it and when engine is running i can push down on each corner pretty well with all of my weight behind it, not easy though.
Have fixed heating by replacing pollen filter and also while i was there giving motor a good whack.
Post Reply
