Xantia Non Starter
PicassoPigeon
Xantia Non Starter
Unread post by PicassoPigeon »
Went to go home from work last night and my xantia was making some awful clicking/cracking noise every now and then and the engine would shake just as it cracked.
Off down the road and then at the end the car just cut out, it then would not start. Would only turn very slowly.
After trying to start again today, it was slow to turn and made some awful squeaking noise as it turned.
Any ideas?? Thanks.gav425
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
mpr1956
Unread post by mpr1956 »
Hi there, I wonder if your rubber-mounted drivebelt pulley has failed.. this is a known problem.. ( have a look down the timing belt end of the engine -this pulley is on the end of the crankshaft)
I won't do that again
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
mpr1956 wrote:rubber-mounted drivebelt pulley )
1997 Xantia?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 1432
Another non starting Xantia
Two in two days? Sounds just like it! :roll:
jeremy
Unread post by jeremy »
I wonder if something has siezed - like the alternator (second this week! - but generally rare)
I'd start by having a really good look around at the belt end of the engine - and see if anything looks distressed - belt shredded, rubber dust, stains associated with overheating then remove the auxillary drive belt and see if everything is nice and free (tensioner pulleys etc) - then see if the cambelt is still present and looks in order. No reason why you can't turn the engine with the auxilliary belt off - and see if it turns properly if you are convinced the cambelt is still there.
jeremy
PicassoPigeon
Cambelt is still ok and after removing the aux belt the engine started fine.
The alternator cannot be turned with my hand is that duff?
Also the hydo pump is quite stiff, although as you turn it with your hand it does get loose and then stiff again and then loose.
Everything else is fine and spins very easily.
Thanks.
125,000 miles
AndersDK
Unread post by AndersDK »
Anders (DK) - '90 BX16Image
