BERLINGO CLUTCH
andy76
BERLINGO CLUTCH
Unread post by andy76 »
H all, i have recently bought an 1.9d 02 berlingo with 20k on the clock the problem i have is that the clutch bites very high, it dos not slip and gear change seems fine.
Is this normal for citroens and can i adjust the clutch manually?
x 1237
Unread post by Peter.N. »
I dont know your particular vehicle, but they are mostly self adjusting now. Providing the pedal still has some free movement and is not against the upper stop, it should be OK.
Ian Fearn
Unread post by Ian Fearn »
I suspect this is the older style manually adjusting clutch as this will be the DW8 engine.
Look on top of the gearbox for the clutch lever and cable. Undo the 2 nuts on the end of the cable and allow it to pull back through the lever. Undo it a little at a time until the biting point is nice and low again on the pedal travel.
1983 2CV6 Charleston 110k (Re-build in op!)
1993 BX TZD Turbo
1991 BX GTi 4x4
1989 BX GTi 4x4
1991 BX GTi Auto
1998 Xantia V6 Exclusive
AndersDK
Unread post by AndersDK »
If not as pr Ian - you may have a cable problem.
Better give your dealer a call with your detailed Berlingo info to work this out :
(Please note that even the dealers may have a hard time figuring out the correct part :roll: )
0400 04 314226 CLUTCH PEDAL CONTROL CABLE BVM BE3R ET CONDUITE A DROITE DEPUIS OPR 07973 JUSQU'A OPR 09456
0400 04 314226B CLUTCH PEDAL CONTROL CABLE BVM BE3R ET CONDUITE A DROITE DEPUIS OPR 09457
http://www.citroen-pr.net/catalogues/il ... 142260.gif
05 - 2150.R4 - CABLE-CLUTCH
- INJECTION XU7JB AND BE3R MANUAL GEARBOX AND RIGHT HAND DRIVE
- XUD7 DIESEL AND BE3R MANUAL GEARBOX AND RIGHT HAND DRIVE
- DIESEL XUD9 AND BE3R MANUAL GEARBOX AND RIGHT HAND DRIVE
- DIESEL DW8 AND BE3R MANUAL GEARBOX AND RIGHT HAND DRIVE
- DW8B DIESEL AND BE3R MANUAL GEARBOX AND RIGHT HAND DRIVE
0400 04 314230 CLUTCH PEDAL CONTROL CABLE BVM BE4R ET CONDUITE A DROITE JUSQU'A OPR 09456
0400 04 314230B CLUTCH PEDAL CONTROL CABLE BVM BE4R ET CONDUITE A DROITE DEPUIS OPR 09457
http://www.citroen-pr.net/catalogues/il ... 142300.gif
06 - 2150.AG - CABLE-CLUTCH
- GEARBOX BE4R AND RIGHT HAND DRIVE
Notes :
DEPUIS OPR 07973 = Oct '98 on
JUSQU'A OPR 09456 = Until Oct '02
DEPUIS OPR 09457 = Oct '02 on
Anders (DK) - '90 BX16Image
andy76
Thx for the replies :D
