Xantia 1.9TD yr 1999 Rough Idle
f00lzz
Unread post by f00lzz »
Hi. Would appreciate any suggestions....have recently developed a rough idle... reminicent of a missfire on petrol mtrs... goes smooth as soon as I increase revs above idle, I havent done anything to cause air in the fuel system, in fact havent done anything except change oil and filter in the last month :oops: Clues please :)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
jeremy
Unread post by jeremy »
Any smoke? Does it start well? Is it loosing any water?
jeremy
x 1238
Unread post by Peter.N. »
As above. Does it emit blue/white smoke on tickover? if so its probably down on compression on one cylinder. Another possibility is that the feed to one injector is leaking, that would manifest itself as a wet engine and strong diesel smell.
Dave Burns
Unread post by Dave Burns »
Is it a consistent missfire on the same cylinder, crack injector unions one at a time to find which one.
Dave
f00lzz
Thanks for the replys guys...
1. Starts fine
2. No smoke on startup
3. Irregular missfire sometimes only like a missed beat sometimes worse!
4. Not losing water (gasket replaced 10k ago)
Keep going guys :)
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
