I changed my idle speed stepper motor (if that's how it's called),
how can i reset it?
What should i do now? the enginge still shut's down on idle speed (mostley when the RPM's coming down from around 3000-4000).
How can i check if the idle speed motor is working?
Also there is a small bold on the throttle wheel, that can raise the idle rpm, how should i set him? (assuming someone touched it)
Thanx, Erez.
