Checking and renewing gearbox oil
debutant
Unread post by debutant »
Does anybody know how to check the oil level in the gearbox of a Xantia 1997, 1.8i, 16v? I tried to work it out with the Haynes manual but no luck .... there should be a way or is the oil connected to the engine oil (doubt that though).
Thanks,
John
Dumped my Escort XR3I for a Xantia <img src=icon_smile_big.gif border=0 align=middle>
Dave Bamber
Unread post by Dave Bamber »
Have a look in the N/S wheel arch where the gear box pokes through, follow the bolts around this, you should find 19mm (or 17mm, can't remember) bolt head, that should be the level plug. The drain is on the bottom of the diff casing. If your going to change the oil, get the right grade as I think is a synthetic type. I changed mine on my old BX and put in EP90 and the bugger wouldn't go into gear when cold!!<img src=icon_smile_blush.gif border=0 align=middle>
Berlingo HDI Wicked<img src=icon_smile_evil.gif border=0 align=middle>Red
debutant
Thanks Dave,
I will have a look when the weather get a bit more "normal"!
Cheers,
John
