does anyone know where the relay or pressure sensor is for the fuel tank pump, i can get the pump to work by putting a live to the pump fuse, but it wont work off the ignition, any ideas?
cheers
HDI tank pump, relay/pressure sensor ??
joelataxi
Current Xantias
1996 LX 1.8 16v ..........breaking
1999 HDI 110 exclusive 206k + counting
2000 HDI 110 LX 86K
2000 Dual fuel 1.8i 16v 188k....resting
1997 vsx 1.9td estate 147k
2000 HDI 110 LX 86K
jeremy
joelataxi
i wish it was!
the hdi tank pump should run for about 10 seconds when the ignition is turned to position 2 or staright to start position.
The pump wont run off the igninition at all, so no fuel no start.
i can only get the engine to run with a live feed to the pump, so by what you say it may be the ecu...doh
i thought there may be a pressure sensor on the fuel line somewhere but i havn't come across one yet, there is a smaller brown electricery box in the ecu case, i've swapped this with a known working one, but still no joy.
(i swapped this as on the running hdi it gives a relay type click as the pump turns off)
Current Xantias
2000 HDI 110 LX 86K
2000 HDI 110 LX 86K
- x 1044
