Haynes Manual
BrianM
Haynes Manual
Unread post by BrianM »
Can anybody tell me if the Haynes manual named
"Haynes worshop Manual Citroen Diesel Engine 84/96 A/N"
covers the 93-97 Xantia TD engines ? ie will it give me enough detailed information to do the timing belt and head gasket ?
Brian
97 Xantia TD
93 Xantia TD ( RIP ) - but hopefully due for reincarnation !
AndersDK
Unread post by AndersDK »
This manual covers the diesel engines found in the Visa & BX series - ONLY
To some extent the manual will cover later generation standard diesel engines - but many details have changed as demands for environment control has been ever growing - and hence the addition of electronic gadgets.
I'd say the standard Haynes Xantia manual may be more accurate on Xantia diesels. Its just that this manual is the late generation Haynes with lots of technical details left out - as "buyers were not interested anyway".
Should however cover the timing belt replacement in details.
Anders (DK) - '90 BX16Image
VW Man
Unread post by VW Man »
