Hi and thanks for helping, my wife has got a 96 Xantia 1.9td and have now got total light failure all headlights dip/full and sidelights (and maybe the codepad too) all fuses are okay, not that they would all go but looked at them anyway, if you can help please email Richard [email protected]
Xantia 1.9TD Total light failure, help needed
ACTIVE8
- x 6
Post in wrong section.
Hi VW Man.
Thanks for the post, but to be able to get the most views and an answer you will need to repost this question in the Citroen section of the forum.
Clogzz
- x 40
ACTIVE8
- x 6
Clogzz
- x 40
Hi ACTIVE8,
It looks like this topic got transferred to this section today.
I’m no longer too sure of what loom causes the problem.
I first thought that the one passing along the back of the radiator was causing the problems because on some cars the openings of the shroud pieces are at the top and taking in water, while normally the openings are meant to be at the bottom.
There are posts about another loom passing under the radiator, not visible through the top, and only accessible by removing the bumper.
Maybe that the latter is for the Mk II only.
If the OP gets back, we may get some clarification.
Regards,
Terry.
Regards,
Terry.
2002 C5 2.0i AL4 239,000 km 76372389
VW Man
VW Man
[email protected]
[email protected]
VW Man
This is just about the best car web site on the net, if you know of any better one's list on here and we will have a look.
VW Man
[email protected]
[email protected]
AndersDK
