Failed MOT
mallyg
Failed MOT
Just taken my M Reg Xantia 1.8i dimension for MOT and it failed on a couple of things. Among the failed items is:- Offside handbrake lever mechanical brake component has restricted free movement and Offside rear brake recording little or no effort.On the advisry notice is a the statement Parking brake. Your vehicle has only just met the required park brake efficiency. I assume the items are linked together but not being mechanically minded can anyone give me any ideas
1995 Xantia 1.8i Dimension
- x 94
hand brake lever not returning to fully off position is usualy either the outer
cable cracked and holding the lever on,or the lever needs lubricating inside the rubber boot on the rear of the caliper,first ly unhook the cable from the lever on the caliper to see if it returns to the fully off position
regards malcolm
regards malcolm
- x 1434
"I assume the items are linked together"
Unlikely, since the Xantia handbrake is on the front wheels...
most likely cause of the rear brakes not working is corrosion between the arm and caliper causing it to twist, followed by the whole lot sezing up. I had to remove the caliper and saw the pads in half to get them out on my previous one....
- x 94
Homer
- x 16
- x 94
AndersDK
Servicing the brakes should be done at least once a year - exactly to avoid such a MOT failure - and to prolong the usable service life of all components. Not speaking of the secure feeling that you KNOW its been serviced
Its a basic DIY job - easy to teach yourself. First time you simply stock a complete service kit including all 4 discs, pads, pads fitting kits, handbrake cables & alupaste.
Then you are 99% prepared to catch up with all wear related problems. Any items not used will be at hand at next regular service then.
You will however get dirty hands to save the £££'s else spent on a garage bill.
Anders (DK) - '90 BX16Image
mallyg
thanks all
Unfortunatley i have a disability prevents me from working with my hands, on items such as this, is anyone in the sconthorpe area who would be willing to help take on the repair. all expenses paid of course and reasonable remuneration. I need it doing before the 26th of this month as MOT runs out then. and i need the car Monday to Friday to get to work so weekends would be great. OH Yeah the first 'O' in Sconthorpe shoud be a 'U' but i will leave you to work out the reason why
