Clutch Cable.
jmd
Clutch Cable.
Unread post by jmd »
While my clutch is fine at the moment,there is no further adjustment available on the clutch cable. Can there be an extra piece braised,or welded onto the clutch cable to facilitate further adjustment if (& when) required at a later stage. Or is my next step a new clutch ?. There is 150,000 miles covered on this clutch, so I suppose at this stage it owes me nothing, considering that a Main Dealer advised fitting a new clutch 50,000 miles ago,(quoting £350 - £400 for the job, as the clutch pedal was difficult to move. However a new clutch cable solved that problem. Any ideas?
alan s
RIP 2010
x 6
Unread post by alan s »
On a CX I once had a similar problem with, I used a couple of washers and a nut between the adjusting nut & the arm to act like a spacer.
The cable eventually broke so I suspect the cable was in the process of stretching rather than the clutch collapsing. Mind you it took about 7 years for the cable to snap <img src=icon_smile_cool.gif border=0 align=middle>
Alan S
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
What vehicle are we talking about? If it's a BX, it occurs to me that some of them had dicey pedal boxes that tended to bend. If you do have a BX, check around the pedals for splits or deformed metal. It can be strengthened with welding.
jmd
Thank you Alan,& JohnD. JohnD the car concerned is an Xantia,(96TD)which I should have stated at the outset.
bencowell
Unread post by bencowell »
I have a '99 Xsara with a supposedly self-adjusting clutch, but that is a load of nonsense. I cut a gap into a washer and inserted it to the radiator side of the clutch cable at the gearbox end. This then made gearchanges smoother.
Ben
MW
Unread post by MW »
Nice one, Ben. I'll give that one with the split washer a go myself.
My 95N Xantia's only done about 84K, but the engagement point for the clutch is getting rather close to the floor and my gear changes aren't as smooth as they used to be. Not crunching exactly, but gently grumbling.
Speaking of which, I bought a spare clutch cable this year to stick in the boot before I went off for my hols in France. Apparently, a right-hand-drive clutch cable is the one component that your average Gitane-smoking Citroen garage-owner in France simply can't get his hands on for love or money. 'Cos his customers all drive left-hookers, of course, and there's no demand for the Eenglish version. Fifteen quid well spent, if only for the peace of mind.
Mike
