Back to the climate control on the 406 again.
Had a new condensor, regassed twice as the seal on the pipe in the rear of the pump was leaking and now all ok.
However, the air coming from the vents is 18 degree's (ie not cooling much).
Guy who done regas is stumped. Says it may be cabin sensor ( little fan is working).
Fan increases in speed when cabin hot. Air compressor clicks on just after startup.
When it's not too hot it seems the air is cooler. When sun in Cabin very ineffective.
I thought maybe dash top sensor but Peugeot say they never go wrong.
Is it a main dealer check over or is there a common fault?
Hope you can help cos I'm melting!
