Xsara 1.4 economy
Allanxantia
Xsara 1.4 economy
Unread post by Allanxantia »
How would the real life economy of this compare to my Xantia 1.9D? Been offered a cheap one.
johninderbyshire
Unread post by johninderbyshire »
i get 38-40 miles to the gallon out of mine (when it works lol)
john
howiedean
Unread post by howiedean »
johninderbyshire wrote:i get 38-40 miles to the gallon out of mine (when it works lol)
john
I get about the same 36-42, although the road tax will be cheaper than the 1.9d.
The 1.4 is a bit underpowered and has to be stretched to keep up with traffic. We got ours as a second car which will not cover many miles.
John what problems have you had with yours?
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
johninderbyshire
Where shall I start?
-broken exhaust manifold
-broken wire in door loom and now blipper key don't work (i aint paying stealer prices to get it re programmed)
-alternator light keeps appearing although there appears to be nothing wrong with it
-just replaced head gasket for no reason it seems as it turns out to be a resistor thing that screws in near the fan (spent nearly £300 for the sake of a £6 resistor grrrrr)
-its eaten 2 anti roll bar links on drivers side
-strut on drivers side
-lower ball joint on passenger side
-had lots of bother with air con etc etc
Can I ask what temp yours runs at? Mine seems to run at around 90 all the time! Is this normal?
John
howiedean
johninderbyshire wrote:Where shall I start?
John
Mine runs at 90 or there abouts as well so I would not be too bothered, at least you know the thermostat is working OK. The 1.4 is not the smoothest engine and to be honest I'd probably want something bigger if I used the vehicle for longer journeys.
So your car was overheating because the fan was not kicking in?
Howie
johninderbyshire
yes, basically. the stage 2 fan came on, but the stage one wasnt.
x 1238
Unread post by Peter.N. »
Stick to the diesel - you know it makes sense!
